Мозг Человека Сразу После Вскрытия (Видео)
Отправлено 04 2017 - 04:25
  • 9501 сообщений
Our brain is the most complex object in the universe. And with over 7.146 billion models, it is also the most ubiquitous.
However, despite using it every day, we are also unsure of how complex it really is. We still don’t really understand how it works.
The three point three pound wet mass – grey on the outside and whitish pink on the inside – controls everything that we ever do.
That’s why this below video is remarkable. For most of you, this will be the first time you see a brain in flesh, as it is removed straight from autopsy.
As neuroanatomist Suzanne Strensaas says in the video, most of us tend to think that the brain is like a rubber ball. However, if you’re a trauma surgeon or a neurosurgeon, you realize that the brain is really very, very soft and much more vulnerable than the impression you get from textbooks.
As she holds the 1.4 kg (3lbs) brain in both palms, it’s crazy to realize that that was someone’s entire set of life experiences. As Suzanne explains, the cancer patient whose autopsy this brain is from, died from cell transplant complications. It’s truly a remarkable gift to science that this patient donated their body.
This video is also important for helping us realize how fragile our brains really are.
You can see how much care needs to be taken when handling the brain. Even though the brain is suspended in the skull and surrounded by spinal fluid to act as a cushion, it really doesn’t take a significant amount of force to cause injury. One good hit on the football field, a fall down some steps or even falling off a bicycle can be enough.
Here is the whole video. It’s also probably important to warn you that it is quite graphic (but also amazing at the same time).
----------------------- ТЕХНИЧЕСКИЙ ПЕРЕВОД НА РУССКИЙ --------------------------
Наш мозг - самый сложный объект во Вселенной. И с более чем 7,146 миллиарда моделей, это также является самым вездесущим.
Однако, несмотря на то, что каждый день мы используем его, мы также не уверены в том, насколько он сложный. Мы по-прежнему не понимаем, как это работает.
Трехточечная трехфунтовая мокрая масса - серая снаружи и беловато-розовая внутри - контролирует все, что мы когда-либо делали.
Вот почему это ниже видео замечательно. Для большинства из вас это будет первый раз, когда вы увидите мозг во плоти, поскольку он удаляется прямо из вскрытия.
Как говорит в своем роде нейроанатомист Сюзанна Стренсас, большинство из нас склонны думать, что мозг подобен резиновому мячу. Однако, если вы хирург-травматолог или нейрохирург, вы понимаете, что мозг действительно очень, очень мягкий и гораздо более уязвимый, чем впечатление, которое вы получаете от учебников.
Поскольку она держит мозг 1,4 кг (3 фунта) в обеих ладонях, это безумие, чтобы понять, что это был весь жизненный опыт человека.
Как объясняет Сюзанна, больной раком, чья аутопсия, от которой состоит этот мозг, умерла от осложнений трансплантации клеток. Это действительно замечательный подарок для науки, который этот пациент пожертвовал своим телом.
Это видео также важно для того, чтобы помочь нам понять, насколько хрупкими являются наши мозги.
Вы можете видеть, как много внимания следует уделять при работе с мозгом. Несмотря на то, что мозг подвешен в черепе и окружен спинной жидкостью, чтобы действовать как подушка, на самом деле не требуется значительная сила, чтобы причинить вред. Один хороший удар на футбольном поле, падение на несколько шагов или даже падение с велосипеда может быть достаточно.
Вот видео. Также, вероятно, важно предупредить вас, что он довольно графический (но одновременно и потрясающий).
